So I have been searching for an hour, and I'm more confused now then when I started.
I have a lifted truck that rarely sees RPMs above 3k. (ok that's a lie..but i want this discussion to be in the idle-3500 rpm range) I have an aftermarket, larger 3 bolt tb. (I think it is 80mm, I ordered it a few years back, I can't remember, I just know it was for a ls1 car, and came with a small spacer to make it work for the truck)
1)Given unlimited money/modification what is the best manifold to run?
2)Given unlimited money and a DIRECT BOLT ON, what is the best manifold to run?
3)What is the most economical DIRECT BOLT ON manifold to run?
I have been looking for used FAST intake, but after reading through old posts it looks like they might need custom fuel rails and/or brackets. Also found a dyno chart and it didn't look like it made ANY extra power until top end.
I found a lot of talk about the tbss intake. They are A LOT cheaper, but no one seems to have a dyno chart. I'm assuming this is a direct bolt on.
I looked into the ls6 style manifolds, but once again, they only seem to help top end, and I don't want to modify anything for power I'll never use.
