finally took out the v6 and put in a 4.8 im getting fire to the plugs and fuel to the rail but the truck wont start, anybody got any suggestions
Does it try to start and then immediately die or just nothing?
Have you checked the fuel pressure?
Where are you in OK?
^^^^ x2
These motor's and ECM's are very ground picky!!!
Good point about the grounds. Check both of the ones on the back of the block.
im in mcalester the grounds are good it just turns over hasnt tried to fire up yet
Even with some ether?
havent tried any
are the fuel rails backwards, lol i did that on mine the first time
na garrison and chic set that stuff up
ok now ive found that only 3 injectors are pushing fuel the truck started but acted as if it were running on 4 cylinders so we pulled spark plugs to see which ones were firing, then pulled the fuel rail off evidently i have about 5 injectors that arent doing their job because they had no fuel on them so is it possible to clean injectors
anyway i could get 8 of them from you i could problably meet you in ada tommorow about 6 or something
the harness is for an 05 with a 4.8 and idk on the injectors got them from chic
:sigh:
Alright now i have fuel to the engine and have lost power to the coils im getting no spark this is getting aggravating
it runs now thanks for all the help
