my trusty old RF 325.1 is down... :( when everythings hooked up normal and playing the subs just make a static noise. if i unhook the remote wire the power light and amp stay on. i pulled the cover and put it in my 240 and it does the same thing
so anything to check inside the amp?
Send it to Rockford or buy a new one.
Make sure the sub moves freely by pushing directly on the center of the cone. Also check to see if any stray "hairs" of wire from the power wire are touching the remote terminal. If you want to open the amp up, look for anything that looks burnt.
ill check. i opened the amp up and couldn't see anything. it starting sounding right for a few seconds then right ack to statis/no bass.
Did you push on the sub?
ill try that? what am i feeling for? i did try different subs...
It's a ghost amp if you take off your remote power wire, and it stays on. Look inside the amp and see if the power, ground, and remote wire bus is some how shorting to ground or something.
its easy to push in
