Guys...YOU'RE WELCOME. :dancenana:
LS General Charts
Seriously...go ahead. Take a look. I personally pooped my drawers after finding this. :cowl:
LS General Charts
that is AMAZING!!!!!!!!!! thats gotta be so helpful
This has been posted before but some how disappeared...
Good find, Tyler! Still wondering how you came across this while searching gay porn?? I bet you were disappointed when you searched shafts and got cam shaft instead!! :LOL:
Sticky FTW!!!
Yar. You poops pants too much mang
SWEEEEEEEEEEEEET We need a engine sticky. "OMFG" is probly not a great title, tho :LOL:
Ha Ha Fail!!!!!!!!!!!!!!!!!
LMB. Everyone.
But hey--look where this is in the Mechanical section...on top. Same place that Jay's mom likes to be. :dancenana:
Nice find.
Thanks Tyler!
so glad i found this. thanks.
playing online and found some additional pn's, some may be double from the original link but tried to skip the doubles
Sensors
#12601822 -Replacement Knock Sensor Harness for Truck
#12102621 -Just the Knock Sensor Connector Pig Tail
#12589867 -Knock Sensor SOLD AS A SINGLE
#16040609 -2 BAR MAP sensor
#12580698 -2 Bar MAP LSX engines
#12223861 -3 Bar sensor
#12561211 -CAM sensor LS1 ALL GEN 3 BASED MOTORS
#12560228 -CRANK sensor LS1 ALL GEN 3 BASED MOTORS
#16212460 -Map Sensor
#12570125 -L92 Knock Sensor SOLD AS A SINGLE
#12591720 -L92 Camshaft Position Sensor
#12585546 -L92 Crankshaft Position Sensor
#15326388 -L92 Engine Coolant Temperature Sensor
LS2 COILS HAVE 2 DESIGNS
#12573190 -ROUND SHAPED COILS
#12570616 -SQUARE SHAPED COILS
Internals/ External Part Numbers
#17122490 -GM LS7 Roller lifter This Number is for a single Lifter, They are packaged in sets of 8
#12499225 -GM LS7 Lifter Pack of 16 to 7000 RPM This is the number for a package of 16
#88958689 -GM High RPM Lifters Pack of 16 to 8000 RPM
#12586484 -Yellow Z06 Valve Spring Part number for 1 Spring
#12499224 -Yellow Z06 Valve Spring Set of 16 Springs
#10166344 -Retainer for all Factory springs SOLD AS A SINGLE
#10166345 -Keeper SOLD AS A SINGLE SET FOR ONE VALVE
#12551162 -Lifter Guide, LS1/LS6 SOLD AS A SINGLE
#12595365 -Lifter Guide, LS2/LS7 SOLD AS A SINGLE
#12551163 -Lifter Guide Bolt SOLD AS A SINGLE
#12569167 -L92 Intake Rocker Arm. SOLD AS A SINGLE
#10214664 -L92 Exhaust Rocker Arm. SOLD AS A SINGLE
#12600936 -L92 Rocker Arm Support Stand. SOLD AS A SINGLE
#12560961 -Rocker Arm Bolt for 4.8's, 5.3's, LS1, LS6, LS2, L76, and L92. Does NOT fit the LS7!
#12571595 -L92 Hydraulic Roller Two-Stage Valve Lifter [SOLD AS A SINGLE
#17122490 -L92 Hydraulic Roller Two-Stage Valve Lifter SOLD AS A SINGLE
#12571596 -L92 Front Lifter Guide SOLD AS A SINGLE
#12571608 -L92 Rear Lifter Guide SOLD AS A SINGLE
#89018058 -L92 spark plug wires
#12600767 -L92 Water pump
#12551926 -L92 Water Pump Bolt SOLD AS A SINGLE
#12587395 -L92Water Pump Inlet
#11516480 -L92 Water Pump Inlet Bolt SOLD AS A SINGLE
#12584727 -L92 Block
#12560272 -L92 Main Cap Bolt SOLD AS A SINGLE
#12560273 -L92 Main Cap Stud SOLD AS A SINGLE
#12556127 -L92 Main Cap Side Bolt SOLD AS A SINGLE
#12563918 -L92 Dipstick Tube
#12574888 -L92 Dipstick
#11519772 -L92 Long Cylinder Head Bolt M11 x 2 x 100 SOLD AS A SINGLE
#12558840 -L92 Short Cylinder Head Bolt M8 x 1.25 x 45 SOLD AS A SINGLE
#12590771 -L92 Intake Valve SOLD AS A SINGLE
#12582719 -L92 Exhaust Valve SOLD AS A SINGLE
#12557840 -L92 Crankshaft Balancer Bolt, M16 x 2.0 x 103
#12576652 -L92 Crankshaft Balancer
#12556582 -L92 Crankshaft Sprocket
#12561513 -L92 Crankshaft Key
#12584997 -L92 Crankshaft Assembly
#12602448 -L92 Flywheel
#12585994 -L92 Camshaft Position Actuator
#12588151 -L92 Camshaft Position Actuator Valve
#11561283 -L92 Camshaft Bolt, M16 x 1.5 x 63
#89018166 -Truck Water Pump
#89018053 -LS1, LS2, LS6 Water Pump
#89018052 -LS2, LS3 and LS7 Corvette Water Pump Only
#12586482 -GM HD Timing Chain
#12576407 -cam gear LS1- Trucks
#12586481 -cam gear LS2
#12556582 -crank gear
#12565308 -02-04 LS6 Cam
#12571251 -05-07 LS7 Cam
#12553118 -LS1 LS2 Balancer for car aplications
#12576652 -TRUCK Balancer for 4.8 5.3 6.0
#12557840 -Balancer bolt
#12586665 -OIL Pump
#12573460 -Rear Oil diverter W/Oring (AKA the Barbell in the back of the block)
#12560272 -Main Cap Bolt SOLD AS A SINGLE
#12560273 -Main Cap Bolt W/Stud for windage tray SOLD AS A SINGLE
#12556127 -Cross Bolts though the block into the side's of the main caps SOLD AS A SINGLE
#12570326 -Cylinder Head Dowl Locator SOLD AS A SINGLE
#89060420 -Fuel Presure Regulator Truck Return style fuel systems
#88862586 -EOS GM's Engine Assemebly Lube Oil Additive 1 Quart
#12559353 -24x Reluctor wheel
#12586768 -58x Reluctor wheel
#12563918 -Truck Dipstick Tube 99-07
#12558684 -Truck Dipstick 99-01
#12610053 -Truck Dipstick 02-07
#15203890 -HD OIL Cooler Line set 99-04
#12570623 -Oil Filler Tube
#89017365 -Truck Intake 4.8, 5.3, 6.0
#88894339 -LS6 Intake Manifold KIT w/o EGR This kit includes the intake manifold, intake seal P/N 12560251, intake manifold gasket kit P/N 12533587, throttle body seal P/N 12552542, map sensor P/N 16212460, map sensor seal P/N 16194007.
#12552344 -LS6 Intake manifold bolt SOLD AS A SINGLE
#12568002 -LS6 Valley Cover
#12573109 -LS6 Valley Cover pcv tube
#12554679 -Clip that hold the injectors to the fuel rail SOLD AS A SINGLE
#24500246 -Clip that holds the fuel regulator to the fuel rail SOLD AS A SINGLE
#12602448 -Standard Fly Wheel All LS1, LS2, LS3 engines To 4L60E/4L65E/4L70E
4L80E Conversion part numbers
#15000206 -Converter dust cover
#12551367 -6.0L Flexplate
#12563532 -6.0L Crank Spacer
#12553332 -Flexplate bolts SOLD AS A SINGLE (6 required)
#15198439 -4L80E Dipstick tube
#15183801 -4L80E Dipstick
#15013290 -4L80E Shift cable bracket at transmission
#11589040 -4L60/65/70/80/85E Toque converter bolt SOLD AS A SINGLE (6 required)
#15767858 -The tranny mount can be re-used because they use the same part number.
14 BOLT 9.5 SF Part Numbers
#3920486 -u-joint straps for 1350 U Joint SOLD AS A SINGLE (2 Required)
#14018700 -Strap Bolt SOLD AS A SINGLE (4 Required)
#19180849 -Axle Shaft Seal SOLD AS A SINGLE (2 Required)
#26064029 -Pinion Seal
#26063649 -Rear Diff Cover Gasket
#19133288 -Rear Diff Cover
#457108 -Inner Pinion bearing
#9417781 -Outer Pinion Bearing
#11505123 -Diff Side Bearing SOLD AS A SINGLE (2 Required)
#9439561 -Wheel Bearing SOLD AS A SINGLE (2 Required)
#12479321 -Carrier Gear kit W/O Limited Slip
#26060414 -Carrier Pin W/O Limited Slip
#12471409 -Carrier Gear kit W Limited Slip
#14012700 -Carrier Pin W Limited Slip
#12337937 -Gear side washer W/O Limited Slip
#14039026 -Pinion Washer W Limited Slip
#12471390 -Right Clutch for Limited Slip
#12471408 -Left Clutch for Limited Slip
found more goodies on the St Catharines gm power train plant employees website.
http://gmpowertrain.ca/product.html
:jumper:
None of these links work anymore
