Hot trans
Ever since the turbo install my trans runs hot. I mean just sitting at the carwash inline i got up to 275. Driving its 250 or alittle higher. Its an HD so i know i have the better tranny, plus the guy i bought it from did a trans go shift kit, bumped up the line pressure, kevlar clucth packs, billet to steel input and output shafts. Will a bigger trans cooler help?
it should are u not running one now?
WOW! You need it down around 170-190.
It has the stock cooler thats it. Oh and I have the harness for my e-fans from allen, I forgot where that other green wire goes to make them kit on faster?
You need to get a trans cooler and change the fluid ASAP. Once fluid gets that hot, it breaks down and doesn't perform like it should leading to premature failure. Wow....Tru-Cool 40k is what you need.
if you have the pressure bumped up in trans AND in your tune, might be TOO much.
You def need an external cooler, big as possible, tho I'm not sure how just a turbo would affect the trans temp unless you are beating on it...or have the pipe running too close to something
It absolutely couldn't hurt to put it on there. Your water temp must be sky high if your trans temp is that high. I wonder if you possibly have a plugged up cooler circuit?
wow....and i thought 200 was hi...
+1 to all the above...I get nervous when my trans runs anywhere above 200.
Take a look at how much clearance you have between your trans cooler lines and your exhaust setup. Might wanna consider wrapping that exhaust.
And, +1 on the big trans cooler.
Engine temp is fine. I have a 160 themo stat. I just changed the fluid. It maybe has a thousand miles on it.
it doesnt matter if it has 5 miles on it, once it gets that hot it will break down and cause issues! you need to figure out why its all the sudden running sooo hot and get it fixed ASAP or you will be buying a new tranny soon!!!!!! im not bein a jerk, just trying to make sure you dont end up having some issues
Yah the last thing i want is to have to replace the trans
Well guys i pulled the dip stick for the trans.... and its over full! My buddy who helped me change it, must have overfilled it, So could this be why its running hotter?
