On my 86, I swapped a 6.0/4l80e. Used a 91 burb cluster, everything works, need to get my ecm retuned to get the speedo right, just swapped gears...
I went with street and performance headers, pricey, but they fit without a problem and look great.
As far as a/c, depends on how you mount the motor, which plates you use. Mine is set back, and I did not want to notch the frame, so if I wanted a/c I would have to run the hiside kit.
Also, I had a 305/th350, all I had to do was get a crossover ujoint, my driveshaft was correct length. :)
I am using stock radiator, no problems. I did mount a set of z28 electric fans running off my ecm. Working great.
I am also using an 87 tank with 87 sender and walbro intank pump.
On your stock tranny xmember, you will have to modify, I welded a "tongue" on the backside to accomodate the 4l80e mount which is a little longer.
Finally!!! 6.0 POWAH!!!! - The 1947 - Present Chevrolet & GMC Truck Message Board Network
check out my thread...
