Hey guys does anyone know where the vacuum lines on a 2500 with a 6L. Looking around can't find any. Does have hydroboost. Thanks for the help.
not sure exactly what you're wanting, but there will be one on each valve cover.
and one for the fpr to the top of the intake.
Looking to put a vacuum gauge on it. I was comparing mine to the picture in my Chilton's book and the line coming off the intake was on the side.
Should be one on the back of the intaake ,passenger side.little one .usually the only vacuum port.
There are no vacuum lines....that's why they're hard to find. There are places you can connect a gauge....but why? Guess an older one will have one to the FPR.
I have one ,just break the titty off.lol,passenger rear .
Thanks guys. It didn't look like I had any vacuum lines that I could see. I would like to put a vacuum gauge on to check the engine. GasGuzzler where are the ports to put a gauge on the engine?
Not sure. I think there is a port or two that come plugged, you could break off the tip like others have suggested. Anyone have a pic?
Its real easy bud,pass side of intake,toward the back ,toward top ,its thew size of a small vaccuum line,nip it off and use it,ive got 2or 3 things on it trust me its there .loooots of people use it.
Found the port. It's on the passenger side about in the middle of the intake. Didn't even pay attention to it earlier. Thanks guys for your help. If I get time I will take a picture for everyone to see.
glad you found the port that wasnt there.lol.good luck
