Waterpump spacer for Fbody pump on truck engine
Well, got the spacers made and test fitted. Worked beautifully.
Stock
http://i47.photobucket.com/albums/f1...r/P3260032.jpg
Removed tensioner. You'll need the Fbody tensioner with the Fbody pump
http://i47.photobucket.com/albums/f1...r/P3260033.jpg
Accessories, no idler or tensioner.
http://i47.photobucket.com/albums/f1...r/P3260034.jpg
notice alignment and short pump pulley
http://i47.photobucket.com/albums/f1...r/P3260035.jpg
Nice pile of expensive parts to remove. Transfer thermostat if you need it and its the same style as your truck unit. Oriellys sells a Murray stat that 180 degrees I believe.
http://i47.photobucket.com/albums/f1...r/P3260036.jpg
Naked waterpump location :wolfwhistle:
http://i47.photobucket.com/albums/f1...r/P3260037.jpg
Nice new parts available from my machinist for $75. Will get cheaper as he sells more but thats what he wants for them now. You'll need 8mm x 1.25 x 100mm bolts, for $10 we can get them for you. You'll also need an additional pair of water pump gaskets.
http://i47.photobucket.com/albums/f1...r/P3260038.jpg
spacers rough installed
http://i47.photobucket.com/albums/f1...r/P3260039.jpg
Nice new alignment :thumb:
http://i47.photobucket.com/albums/f1...r/P3260040.jpg
The money shot.
http://i47.photobucket.com/albums/f1...r/P3260041.jpg
