anybody know if autozone or advance auto can check for codes?
If you're just asking about just getting the code from you ecm, yeah they can do that. I've done it a few times at advanced.
well...i took it there and the code reader says its the knock sensor...
50 bucks more or less for a new one, is this something i can do myself? can i drive around like this for a while cause i really wont have the chance to replace it for another 2 weeks or so...
Yeah you could definitely do it youself. Actually did mine back in october. They sit under the intake manifold.. and there's two of them.
It wasn't too bad. And when you pull it all apart, you may find you need to replace your knock sensor wire harness. Your truck is a 2000 i would say replace it, my 99 knock wire harness was kind of brittle, and broke when I pulled it off. You might even need intake gaskets, they are reusable, but mine were toast were stuck the the intake.
When it was all said and done, it cost me about 200 or so ,that includes computer time and something I broke.. sensors ($40 each), wire harness (about $45), intake gaskets (about $30), fuel line puller ($6) (3/8)
Next time you have a code let me know I can scan it for you with either my plx gauge or my OBDII Scanner. Autozone here sometimes takes forever to scan stuff they are lazy
im not gonna break soemthing else if i drive around for 2 or 3 weeks will i?
Only reason I jumped on doing mine are the amount of miles on my engine.
Knowing the code is 1/10th the way to a fix in most cases although the advice in this topic looks OK. Replace both sensors, the harness, and the intake gaskets IF the wiring and PCM are OK.
Do a search.
Good call guys. It is usually necessary to replace both sensors and the harness. Depending on your mileage, your intake gaskets may be ok....
understandable...this truck is my dd...am i gonna hurt anything if i keep driving it for another 2 weeks or so? mostly highway miles...
118k miles by the way
Well, you can ask the Autozone guys to clear it. They aren't suppose to for legal reasons. Go back in there and tell them you ordered and replaced the knock sensors, and now you need the CEL to be cleared. Once they clear it...wait and see how much longer it take for the CEL to come back on. If its immediately, then I would be cautious... You can drive it, but don't WOT it at all.
