how are u guys installing aftermarket tranny coolers?
where u get the fittings?
any pics?
my truck doesnt have a factory tranny cooler, the lines go in the radiator but no other cooler besides that....i searched but didnt find much info
any pics?
Check those Engine Oil, Transmission and Fuel Coolers
You have the factory cooler in the radiator but not the auxiliary one I guess. There is a GM kit that I'm sure is over-priced and no one uses but I'll look....
yeah...thats what i was trying to say, but the way i said it wasnt very clear....
yeah, i found that kit, if i could just get the lines it would be great, i already have a trans cooler, its just sitting in the shop though, not doing much good there, i thought someone had to make an install kit or something...
Got mine from the salvage yard, all the caddies with the Northstar have oil coolers and they are the plate type rated for 28k pounds for 5 bucks.
ok i have a B&M trans cooler at the house, i just need to install it....i found this link, i want to do this!!
cooler install
im feeling productive today, i think i will mount it up when i get off work and just feel it out from there, ill post up picks of the progress later
I had a tru-cool cooler to install and there were no fittings. The local Orielly store had universal prebuilt brake and fuel hoses hanging in the back. I just tried a few until I found the ones that fit. A cut to make one into two, a couple of bends, hose clamps and rubber hose and it was ready to install. Simple 3/4" x 1/8'' flat bar, a drill, nuts and bolts can make any mounts you need.
so, do the trans lines have the same flare as a brake line?
Look here banker099: http://www.ls1truck.com/forums/mecha...ns-cooler.html
They do not have anything like the flare on a brake line.
BTW, the GM kit for a 99 is $99 and includes the cooler, both pre-bent steel lines, and all the hardware. Not sure what the GVWR is....
well....my cooler just had the hose barbs on the cooler no screw in type fittings, so i used rubber line, as much as i didnt want to, but its on and the trans temps dropped 40*
