Well i have been thinking about putting a turbo on my truck i was wondering what yall guys thought about them and if the sts kit has any benifits over the trick turbo kit
thanx
thanx
turbos dont work.....lol...... sts is somg legal, trick is not.... trick has more power potential. just my .02
well i am wanting to push 15-20 psi if that matters
Spoolin is running 18 lbs right now over on PT.net with an STS. Somewhere up in the 6XX hp range. Course that is with a fully built motor.
You will have fun with either one...or for that matter and FI/power adder is going to be fun.
The biggest advantage STS has over trick is intake air temperature. STS has VERY low IAT's, even under boost and the highest IAT I have ever seen with my intercooled STS kit is about 15 degrees over ambient air temperature. With cooler IAT's you don't have to worry about knock or ping nearly as much as a front mount and you can extract a really good amount of power out of every pound of boost. If you ask me, the STS kit is a lot safer to run, way easier to install and I can vouch for the AWESOME power the kit makes.
Running a meth kit with my front mount has given me about the same IATs...about 10 or so over ambient under full boost. I've heard stories about SOME STS kits having problems with the oil pump, but I don't think that's the case with everyone.
I can vouch for the low IAT's on my truck. Sometimes they get high in traffic, but its never really that bad. I really enjoy the power my kit makes and is going to make on my truck
that is true about the oil pump issue. the guy that owned this before me had problems with the STS oil pump until he upgraded, and I have yet to have any problems with it on my truck *knock on wood*
Hey Ducky if u wanna be sure to never have problems with that sts kit just trade it to me for my Al. 22's
Just thougt I'de throw the option out there for ya!!!!
