Where do you get those pieces that snap on to the fuel lines on the 5.3 motor and adapt them to threads so you can run your braided fuel lines?
Edit: Is this them? If so how do they work do you cut off the flare/lip and these are like a slip fitting?
http://store.summitracing.com/partde...0&autoview=sku
Earl's Performance 165006ERL - Earl's Performance AN to Tube Adapter Fittings - summitracing.com
