hi everyone i blew the 4.3 in my 05 last nite so i have decided to try and do a swap. i have the motor found but my main concern is my truck is 5spd and the donor truck is an automatic, will the wiring harness be different ?
not too much different. Put the auto trans in there too. You'll be glad you did. You'll need remove the clutch pedal and install a shifter but thats easy to do.
no im not gettin rid of the 5spd. id rebuild the 4.3 before i did that.
Time to go flywheel and clutch shopping. If I remember correctly the 4.3L 5 speed flywheel won't work since its bolted to a crankshaft built on the Gen1 engine dimensions.
i figured id have to get that stuff from a 4.8 what im worried about is the wiring?
I can't recall any transmission hookups on a 5 speed going to the PCM other than a clutch pedal position switch.
ok man i really appreciate the info. could this swap be done in a week? im takin the week off from work and i need it fixed by next monday because i use it for work.
Have you ordered a tuned PCM for the new engine? Do you have HPTuner or a programming software to remove the VATS security software? I'd budget two weeks worth of time to do it in since you've not done the conversion before. Be sure you read the conversion posts on here a few times. Ducky did the conversion recently and did a nice job of documenting his obstacles he encountered.
Also, be sure to read the topics related to putting a 5 speed behind a genIII engine.
i have a tuned pcm now with free updates for life. ill be sending it out tommorow i think. im just afraid im gonna get this started and not be able to get the wiring straight.
wiring is a piece of cake. just make sure you get the right harness. Didnt take me but an hour to wire it. Everything is plug and play. Although I did go from automatic to automatic
one more thing ive got factory e-fans and the motor im lookin at doesnt any ideas how to wire that to work like factory?
hi everyone i went to the local junk yard today to pick out my 5.3 i found the one i want its in a 02 suburban but its drive by wire. i saw 02 trucks that had the cable but the burb had dbw. is it alot of trouble to change? do i just change intakes? they had dbc engine but they looked to have been treated alot worse with mud all over then engine bay etc.
can i just change intakes and throttle bodys and use the dbw harness?
i honestly have now idea....i would guess no....
so i guess i need to get a engine with dbc.
just get the harness and tb for dbc
