http://www.ls1truck.com/upload/files...m%20Offset.JPG
Does anyone know that dimension?
Well, if the lifter bore is 0.843-0.844" in Diameter, (the lifter itself is 0.700" in diameter) then the measurement you are looking for (radius) is .4125"-.422" or 10.71mm-10.72mm.
I don't get it, need help.
Your drawing is goofy, the center line of the lifter bore should intersect with the pivot point or arc center of the cam shaft.
The way it is drawn one bank would be advanced and the other retarded. Or is it I that is retarded?:LOL:
Are you asking about the rocker arm to lifter bore tilt that the push rod has?
A lifter bore that is out of round and/or has clearances larger than the lifter indicates excessive wear.
Offset lifters are used with head and/or rocker combinations that require the pushrods to be set away from the intake ports or for any other side-to-side clearance issues. The offset has nothing to do with the tie bar in between the lifters. The lifters have offset pushrod seats left or right for the intake and/or exhaust, or any combination needed to gain clearance. -Crane Cams
I was under the impression that the lifters sat "ahead" of the cam center line, that way, the lobe pushed them in a more upward direction instead of relying on the wall of the bore to direct the lifter up. I could be wrong.
I had always assumed everything was in line untill a buddy of mine said otherwise... since then, I haven't been able to check.
I'd be really surprised if that is how the bores are setup. My assumption would be that the lifter bores are on the same exact centerline as the camshaft. Offsetting the lifters would make grinding a cam a bitch.
we have off set lifters in one of our comp motors the lifters set in the bore just like any other lifter would what is off set is the top of the lifter where the push rod sets. on one side of our motor they are offset all the way to the back on the other side they are offset all the way to the front. we had to do this to clear the intake runners cause we moved them so much.
keep in mind when you offset the lifter you have to off set the rocker arm as well... looks kind of like a dog leg if you will.
I got my measurements from this website I have saved on My Favorites.... Motor Dimensions and Specs. As for that .143 variance, you have to divide that by two cause you are using .143 as what is left over from the bore diameter and lifter diameter. So you have .071" of clearance around the lifter, based on what the specs say. To me, seventy one thousandths of an inch is pretty damn small... I just replaced all the lifters in Alan's truck in Tuesday night and they fit in there decently, but the plastic lifter cups also hold the lifter in place so that it won't wiggle around. And from what I could see, the lifters centerline is aligned at whatever angle to the cams centerline. It looked to me that there was no offset.
Damn good thing you're an architect and not a mechanical designer. :laugh: The slip fit of the lifter bores is closer to .002".
Ok, I am trying to figure out how you got .002". Ok, for math's sake, the area (pi x radius squared) of the cross-sectioned lifter bore is .558 square inches. The lifter itself has a cross-sectioned area of .385 square inches. That leaves us with this buffer area between the lifter and the bore walls of the block at .173 square inches, in cross-section. See pic below:
http://www.ls1truck.com/upload/files...37;20bores.jpg
Now, with those numbers given, lets look at a section through the lifter bore:
http://www.ls1truck.com/upload/files...%20section.jpg
So, from looking at the pics and dimensions of it all, what are we left with?
Damn those pictures suck. Let me go back and make some EPS files and import them into PS and then reattach them...
I used this handy-dandy little device called an OD micrometer and measured the size of a lifter fresh out of the block. .8415-.8420"
.843-.842 = .001 minimal clearance
.8415-.844 = .0025 maximum clearance
http://i47.photobucket.com/albums/f1...t/P2120080.jpg
are you looking at offset in that the lifter is offset in the bore? that is not the case. the offset comes in where the pushrod hits the lifter. if you look at the top of a lifter the hole is dead center correct? now imagine that hole as far to the left or right as possible. that is how they offset lifters. i will try and bring one saturday to the dyno day to show you what i speak of... if you want me too...
lifters are only going to have .001-.002 clearance between the lifter and the lifter boss. that is why on most race motors people insert bronze guides.
