does anyone know what the factory injectors are? my brother was going to hook me up with a set of 28lbs for free
24lbs
for free yeah why not...you will need a tune with them though
then you are good to go...FYI it's easier to pull the intake off to change them out
if they came from an f body they will not be plug and play.
I think they have different plugs that have to be spliced in. pm twobit, he knows more about it than I do and might have what you need also.
Yea, different plugs will be needed as well.
And you will have to install spacers and longer bolts.
hey guys im about too install my 68lbers in my truck,am i gonn need spaccers an if so were do they go?i bought allens 68s i know i have to have to the clip kit that i purchased also but i think i have to space em,im also installingaftermarket fuel rails so idk if i still have too prepare myself to have anything else.sorry too jack u ,off i go .lol.
I used a longer bolt and cut some 3/8" tubing to use as spacers. If you install the injectors in place you can measure how long to make the spacers and longer bolts.
what are the stock 8.1 injectors rated at? And you can run these in a 5.3 with the stock tune right?
