I found some electric fans on ebay and was just wondering if these were the right ones..
eBay Motors: 05-07 CHEVY / GMC OEM ELECTRIC COOLING FAN ASSEMBLY (item 250205464899 end time Jan-19-08 20:55:32 PST)
pretty sure there wasn't a difference between the v6 and the v8. they should work, and just get the nelson harness for 80 bux
I think they are for the 34inch core though. I have a 28inch so no worky
**** you were right jeff. they are for the 34" radiator. I should have asked them guy before I placed a stupid bid. How do I clear my bid?
Just get the 34" radiator from a junk yard. Keep your bid...
on mine I just put Impala e-fans... they work great... only 100bux.
i thought the nbs had 34 inch fans. guess im wrong sorry david. you can get ls1 fans or even GTO fans.
the 1/2 ton trucks had 28" radiators from 99-04. The 1/2 ton Tahoes and Suburbans had the 34" cause of the extra size and heft. Kinda like your mom--she should have the bigger radiator cause of her bigger size and weight... :)
I got them from local shop here in McAllen... I dont have any pics but they are direct fit, u dont have to switch radiators or anything... If u want more info about installation u can PM LaRiddler or LaChochita on the pt.net or on southtexastrucks.com... they have installed over a 100 efans on trucks over here.
Yeah those will work, i bought the same ones and the nelson harness, they are so nice, almost perfect fit, i just made 3 brackets and mounted the fans right to the radiator. i have pictures see if they will work. I bought my fans off of a camaro SS 2001, and the nelson harness took me about 2 hours to put em one and get them working.
what do people reccomend for the OBS trucks like my 98? would the NBS ones work?
As far as ive ever seen, a lot of guys with the 98's and older were using the same fans, because the trucks both had 28" radiators, just have to ask someone about the harness though, because im not sure the PCMs are the same or work the same. Measure your radiator, efans were a great investment.
Yeah, LS1 fans are a great setup. Allen can make you a harness...
LS1 style fans. They come off Camaros and Firebirds (F-body).
I am not 100% sure, but any of the camaro or trans am fans either LS1 or LT1 fans from 98-02 will fit onto the 28" Radiator of the Gm trucks, because the camaros and transams had the same size radiator i believe. not exactly sure, but i have a buddy with a 98 gmc and he put the same fans on as i did, LS1 fans, just he bought a Flex-a-lite controler because he didnt want to pay for a tune and the harness.
