how well dose the finish last on the pacesetter LT's over time. i put a set of flowtech afterburner ceramic headers on my 84 monte ss and they did not last well.
I have a set of LT's that have been on my truck for 8k miles, and just ask Mean05, these things have been through hell and back two or three times, and still look pretty decent as far as the finish goes. No rust at all.
Ive put close to 5k on mine and they still look good
3500 on my pacesetter LTs and still lookin sweet!
Mine Still Look Amazingly Good Still I Had Gibson Stainless 1s And The Color Was Gone In No Time.go For The Pacesetters.youlle Like The Power Diff.
I bought the cheap ones and did black header wrap, looks good IMO
Just be careful, if you DO use header wrap it typically voids any warranty.
yeah ive used header wrap in the past, and if you get the spray on coating and coat them after you wap them, it helps keep out the moisture and therefore the headers and wrap will last longer, and i believe the wrap helps keep more heat in the tubes than the ceramic coating, plus i always liked the way it looked.
Ill probably go this route when i put the LT's on my truck.
Pacestter LT's coating is pretty damn good. I have never heard of anyone complain about the coating flaking off or anything--even up in the North where they get a little more of extreme temps and with the salt...
are there any fitment issues with them? i had to hammer on the prtimary tubes on the flowtechs
No fitment issues here--but I have the 2WD. Some 4WD and AWD applications have had a pretty tough time getting them to slip in there...
where is the best place to order some Pacesetter Headers and y pipe..
I have an 07 GMC sierra 5.3?
Probably close to 30k on my headers and no problem at all. Pacesetter LTS
no probs.. got oil and all kinds of **** on mine. finish seams impervious to any and all deamons under thou hood...
4wd youll have 2 do some playing but if you need some tips pm me.
