1995 Silverado TB350 to 2003 6.0l 4l80e Conversion RUNNING 8-26-07
I have been researching for a couple years and am moving forward with the project as my transmission went out in the truck.
My current plan...please critique or fill in voids...
TransDapt Engine plates
EXHAUST:
Use 2003 exhaust manifolds.. where can I get some flanges that bolt up?: thx Gator
02 sensors how many and location? in Y pipe or near cat(s): removed rear O2's
TRANSMISSION:
Use 4l80e yoke on my current driveshaft
Hook up vehicle speed sensor
FUEL SYSTEM:
Inline 255 Walbro
2000 Corvette regulated fuel filter: not needed as I have a dual line rail
TBW:
The Engine is equiped with it and I believe I have the control Module but need an 03 newer pedal setup. Still need to work on getting cruise control
COOLING:
Check 95 hose to see if they fit. If not head to the local store to find something that'll work: 99 truck hoses direct fit my 34" radiator
Will need Electric fans to cool the radiator Factory F body or Truck?: Used 99 Caprice
Air Conditioning. Fab 95 bracket or make a bracket to mount 95 compressor on..have heard 92 camaro may work with some changes.
WIRING:
Sort through harness Looking for 2003 HD2500 and 1995 C1500 diagrams....any idea? Alldata?: Various sources and troubleshooting
Gauges:
try to adapt 95 sensors to lsmotor
Tach ?
Temp...in head hole... retrofitted TB factory sender
Oil Pressure? Where is a good location to tap in? : Replaced LS sender with TB factory sender
Odometer/speedometer?
ENGINE MANAGEMENT:
Will need to mod factory ... at minimum tire size/rear gear but looking into HpTuners and EFILive
http://www.personal.kent.edu/~wbaine...es/Truck53.JPG
