Wonder how this would work ?
www.hotrodsandhemis.com/Traction.html
You are looking at the design of the Caltracs traction bars. Check out CalvertRacing.com
Yeah , just thought some DIYers would be able to use this .
<div class='quotetop'>QUOTE(use2bfo @ Feb 9 2007, 09:24 PM) [snapback]82802[/snapback]</div>See page four...my truck page :wave:Quote:
<div class='quotetop'>QUOTE(COWL327 @ Feb 10 2007, 02:02 AM) [snapback]82819[/snapback]</div>As always I didnt look at the whole page.....Damn I could have made those...OH well ,Im almost finished with mine and I finally got that vibration out of it when you launch....use2bfo noticed it as soon as he rode in it. I guess I had sort of got used to it :bash:Quote:
i've made mine using that site.
So how did they work , help it hook-up better , what did it wind up costing for them ?
they're working fine. working like they're designed to opperate.
they only hook up with my et streets, don't work with my street tires.
cost was under $100 with half of that being spent on rod ends.
They looked simple to build and as Red stated look just like the Caltracs , which sell for 399 .
cool i think i just found my next weekend project once i get the brackets made...
very cool article and i have all the stuff lying around the garage... :)
If you have any extras let me know :)
<div class='quotetop'>QUOTE(twobit @ Feb 13 2007, 05:55 PM) [snapback]83180[/snapback]</div>Quote:
if you give me some measurements i am sure that i can have some brackets cut for you at the same time... and what size bolts and everything that you have for a small nominal fee... :)
the rest i am sure that you can handle... i have access to a plasma table that is computer operated off cad drawings and the same access to a cnc mill and lathe.. :)
all my brackets will be the same that way.. i dont trust myself ith a drill press and proper alignment...
<div class='quotetop'>QUOTE(outlaw_king @ Feb 13 2007, 10:43 PM) [snapback]83207[/snapback]</div>Sounds good. I will pm you. thxQuote:
