i dont think anybody on this forum is ever "finished"
sadly no i am not... still chasing a misfire... but like kewljay said... even when i am "finished" I will just start researching my next mod...
Just a thought but did you remember to switch the injector firing order?
Cylinders 2 & 3 and 4 & 7
Switch C1-3 & C1-4 and C1-44 & C1-43 at the PCM
I guess this only applies if you adapted your original harness
maybe check your compression with a gauge other than one used previously
I think i figured out my problem for real this time... I had always searched pinouts to confirm my wiring.. and all was correct so I assumed my wiring wasnt the problem. tonight i decided to go over connector pinouts. got 2 sensors in and found a problem.. i figured i would check the ckp and cmp sensors first. CKP was all good. my diagrams showed that the CMP sensor was wired backwards... my wiring guide said to wire signal to pin A, return signal to pin B, and 12V to pin C. I swore I did it backwards.... so I went out and checked.... grabbed my meter and sure to my dissapointment my wiring was correct.... so I thought. I noticed that the connector had a yellow,black/white and pink wire... Hmm... I went back to the diagrams and saw that the CMP plug should have a pink, pink/black, and brown/white wires. so I went digging through my bin of connectors and found the CMP plug. turns out the little letters on the plug notating the pin positions are backwards from the plug i was using. So I had it wired right for the plug, but not for the sensor itself... I was sending 12V to the signal and powering it with the signal from the ecm haha.... now in the morning i get to repin it and hope i didnt fry the sensor.... wish me luck i hope it solves the problem.
random picture whoring...
https://scontent-a-iad.xx.fbcdn.net/...35571435_n.jpg
https://scontent-b-iad.xx.fbcdn.net/...59861105_n.jpg
My old 2dr hoe...
https://scontent-a-atl.xx.fbcdn.net/...95806049_n.jpg
she lives!!!!turns out after swapping a new cps in and rewiring the entire harness i fixed the problems!!! turns out the guide i used to wire the harness is completely wrong... sucks but atleast now i know...
Awesome!!!!!
