Heres some pics of the fabbed up front driveshaft I did. Since it didnt fit, I took some old sleeves (4) I had off my lift kit, cut them down to length, and welded them on the outside 4 bolt holes. Then I had a peice of 3" exhaust, but I found a 3" pipe that was heavier in strength so I used that. I basically cut them so they were 1 1/2". Worked out pretty good. It might be out of balance a little but I dont drive the truck with the front driveshaft in most of the time anyway. It was pretty simple doing this and saved me a good 200 from having it lengthened at a shop. Now I just need to figure out what I am going to do for the rear shaft...
