dayum! 3/4" drive?
dayum! 3/4" drive?
My 1/2" IR only has 650 ft/lbs. I also have its little brother in the 3/8" size. Hahaha. I use a 20" extension and my 3/8" impact with a 13mm shallow impact wobble from Snap-On. I also have a deep 15mm wobble for the bell housing studs.
I picked up a 24" extension and already have 6 points, so hopefully that will do the job.
Nope my CP Turbo is 1/2" is the baddest thing out when i bought it. Paid 235 dollars for it. I use two 18 inch long 3/8 extentions with a 1/2 to 3/8 reducer and my impact and it works great and a impact wobble if needed..... O yea I HATE BUYING CHEAP TOOLS they just dont get the job done......
Down to the last bolt on top...taking a dinner break then gonna go try again.
Once again, I use my 3/8" impact for those nuts and studs.
LOL
It's off. The top middle was the hardest. In the end, I went in the engine bay, put the 13mm socket and a ratchet on it, then climbed underneath and was able to push upward and break it loose. Fron there I had enough clearance to get the 15mm on the main bolt. Came right out.
I am NOT looking forward to putting it back in. :sad:
that sucks man,I just had the tranny in the tbss out and back in in like 2.5 hours.lol
So it's on the floor?
