Its your tensioner probably. Look for the pully that isnt spinning :lol:. If the pullies are still spinning, the one that is the hottest ( I did the water drip test once) is it. Or you can take the belt off and inspect each pully.
will these fit a gen IV 6.2?
well guys a 90 inch belt is to big i meaused it with a flexible tape and that what it came out to but its just to big... i can get pretty much anysize at the auto parts store. should i just keep going down an inch until it stops slipping on the alternator? i think an 88 or 89 will work good....
4060900 (serpentine)
040345 (a/c)
Thats the numbers I have for the belts..thats with UD pulley, a 145 amp alternator and OD alt pulley though. I'd say w/o the 145 amp alt, the belt should need to be 1" smaller.
Wondering if you got any of the pulleys now
PM me if you have more kits!
hello any kits available? also is the alternator pulley a overdrive one or can you get a overdrive alternator pulley? thanks bryan
I haven't gotten any alerts from this board. I'll order more up here shortly, probably within a week. They'll still come with OD alt pulley, crank bolt, etc.
PM ME or email
PM sent :)
