Happy Birthday!! Looks like youll be enjoying a lot of summer cruising!
thanks!!
happy b-day.
No check engine light with that hard of a misfire? Pretty difficult to make anything out from the vid but it looks great!!!
kinda acts like it isn't firing/no fuel on one or more. Looks like its shakin pretty good.
stock LS harness? Reworked? Double check pin assignments, maybe. http://www.lt1swap.com/gen3_schematics.htm
Dumb question, are all the plugs in?
sounds beefy. Cool man
updates.....
and a few pics of earlier stuff...
Got my Gauges installed for tach, oil press, and coolant temp.
https://scontent-a-atl.xx.fbcdn.net/...28072696_o.jpg
https://fbcdn-sphotos-b-a.akamaihd.n...67297490_o.jpg
Coolant and oil sensors on my adapters..
https://fbcdn-sphotos-d-a.akamaihd.n...46678506_o.jpg
https://scontent-b-atl.xx.fbcdn.net/...41625198_o.jpg
special socket for removing the oem oil sensor..
https://scontent-a-atl.xx.fbcdn.net/...23628443_o.jpg
I had a fuel leak on my Earl fitting out of that little hole...... I thought. So I bought new fittings..
https://scontent-a-atl.xx.fbcdn.net/...68382693_o.jpg
https://fbcdn-sphotos-a-a.akamaihd.n...83352055_o.jpg
Turns out i forgot to tighten one of them.... oh well now I have spares.
I borrowed a neighbors welder so I can do my exhaust.. Pipes and bends should be here tomorrow from summit.
Dual 3" with E cutouts back to a dual inlet single outlet 50 series muffler..
https://scontent-a-atl.xx.fbcdn.net/...90423812_o.jpg
Im thinking my shake/ misfire problem was a bad plug....
Nice and wet..
https://scontent-b-atl.xx.fbcdn.net/...79676485_o.jpg
Also got my Headlights and fogs and tails hooked back up and tested..
https://fbcdn-sphotos-b-a.akamaihd.n...94129625_o.jpg
https://fbcdn-sphotos-g-a.akamaihd.n...15626312_o.jpg
Make sure that coil is working correctly on that cylinder. On mine when i first did my swap my truck would idle rough and part throttle was rough but wot was fine. Found #8 coil was bad.
yeah im gonna put a different plug on that wire and turn the engine over to make sure its firing along with all of the others..
Ok, I don't know if I missed it or what but what is hiding
In the grille?
got most of my exhaust mocked up.. now I have to weld it all..
https://scontent-b-atl.xx.fbcdn.net/...37123540_o.jpg
https://scontent-a-atl.xx.fbcdn.net/...14250051_o.jpg
https://fbcdn-sphotos-b-a.akamaihd.n...36564865_o.jpg
https://scontent-b-atl.xx.fbcdn.net/...39992118_o.jpg
[img][/img]
Are you all finished now !!!
