http://i1108.photobucket.com/albums/...psqb0elilh.mp4
That looks awesome! No A/C?
That makes it simpler. I have a Whipple and have to figure out how to run the bracket for the idlers from the passenger side head right where the A/C compressor is mounted.
So how does it feel? How much boost are you running?
Feels really good so far, the pulley I have makes 10psi. Still waiting to get the tuning perfect before I really rip on it. Feels awesome when the boost comes on though!
Any idea why my speedo likes to bounce around alot? Speed sensor is brand new. Throws code p0608. Am i missing something?
what trans was in it before?? you said you swapped a 60e in. it didnt come with that? if you had to extend the purple/? twisted wires or add them if you didnt have them, make sure your connections are solid and that they are TWISTED all the way to the pcm or else it might be picking up interference from other wires and definately will provide interference to others as its a pulsing signal.
Well I doubt 6" would make a difference unless it was next to a big power cable or something. Worth a shot tho. Also I'm not sure how the sensor works in the trans but this happened on my motorcycle. There is a rotor and magnet pickup. The bolt holding the rotor came loose and chewed up the magnet which threw the reading jumping all over like what u describe. Maybe something similar is going on inside yours too?
