Shouldnt spray below 2500rpm because its more prone to detonation
95% of the people spraying off the line have an aftermarket converter which will let them leave in a better rpm...if you are only leaving at 1200rpm that is just way to low and asking for a nitrous backfire...spraying after 3000rpm is the "safe" way to do it and also the old school way of thinking IMO...spray no earlier then 2000...stock verters will usually stall around 1700-1800 for the most part just stand on the brakes and make sure it doesnt stall all the way up to what the window switch is set at
Good times mitch! Throw that 150 on there!
got you updated on the list
headed to the track again today, messing with the window switch a little and that sort of thing... hopefully it will end up better than ennis did for me. also have some different jets in so its a little richer.
first run - 14.6x with 150 shot
second run - 15.2x with 50 shot
then i quit......
what??what happened bro?u running with that ses light??that may be the problem.time to give allen another visit.
haha what the hell is wrong with your truck mitch
