I would like to see more pic's of your AC bracket, it look's like the original 95 passenger side serp. bracket, if it is how did you do it?
The bracket is the original bracket from the 350 small block.
Well it took awhile to find the link on the article, but here it is.
http://67-72chevytrucks.com/vboard/s...d.php?t=510656
The only problem I had was that the tensioner was in the way of the noise baffle on the intake tube. I removed it and siliconed a plug in the hole. I also had a small issue with belt alignment but remedied that with some minor tweaking.
Awesome, thank you for that link!
Glad to help out!!!
http://www.ls1truck.com/forums/lsx-t...or-wiring.html Here is the wiring in this thread and i am pretty sure the diagram comes with the sensor.
