With the ability to adjust ride firmness, I'd imagine it would work well.
If u are looking for someone who can do coil overs on a NBS, I heard DBRods, just got done with one! But that's what I heard!!!
UNDERSTOOD, but if you would read the whole thread not on the 08+ models. All he was statingis that one has been and soon to be posted is a NBS that was done by DBRODS. He can and did a fabulous job, beyond my expectations. And if I missed something I'm sure I will be corrected. Thanks
Jon, will theses work with djm lower control arms? I don't want to put my stock arms on and run spindles bc I want to run 16s or smaller if possible. Thanks
i wouldnt do it, youll be maxed out on shock height ( adjusting spanner ) all the way up, im at the top now, wish shocks would be alittle longer, but its all good! going to fix that issue by flipping the tubular control arm mounts since it lowered the truck way to much!
Jon, I sent you an email, and decided to register to here to try and get a hold of you. I will try the shop on Monday. I am interested in doing the coilover swap on my crew cab. Just looking for a bit more info before I pull the trigger.
Anyone else running this?
Ducky's garage!
