IIRC, back of transfer case on driver's side there is two plugs, check the top one. Maybe someone can confirm this?
yes back of t-case there are two plugs to the drives side of the out put shaft the bottom is drain the top is fill/level check
i vote.... fill that sucka with some thick gear oil...drive until the snow melts...and THEN worry about it :)
ok i got the tcase.. thanks Luke!!!
so.. now the quesion is.. when does it go in..whom can i convince to come help me.. hmmm
They are super easy. pull the driveshafts, a plug, 6 t-case to trans bolts and pop it off! two people is nice to stick it back on but i have done it by myself on my back
