lol i just saw that it was only on a 1.51 60' if he could get that in the 1.4's it would really move
Whats his suspension setup?
my truck is a daily driver and no it does not have a solid roller and it was all done wit a 200 shot off the foot break, and usually traps in the mid 140's
on another note, blacksheep ran that off the t-break with a 300 shot. and a low 1.4 60'
this truck has alot more left on the table, you'll see
could you explain this cam then? i havent seen any non-solidroller cams with a power band like this. ever cam i seen with a powerrange like this is solid roller
im sure its sill go alot in it and i wont argue that, you have alot of money spent in the right departments. and i dont have enough time to search but i thought blacksheep shot wasnt 300 it was less then that
its on the raged edge of being a solid roller but its not, if you have all the supporting parts it will pull that high, lightweight valves, springs ,etc its got all the good **** on it.
but you wouldnt know about it, you havent had as a radical combo as this.
i like to be on the radical side, on aother note i have not been 8500 on it, i,ve been keeping it in the 7800 area:)
if you do a search it says 300
Flacos truck is damn fast thats all i got to say and good luck.
