If your engine has the oil cooler lines or the trans cooler lines you can get the rad with the coolers or go cheaper and skip that part. And then bolt it up, the outside bolts are a different size than the inside bolts. Your rad hoses will stretch a little but they will fit. You will need to cut or move the black asphalt wider to let all the air into the radiator,the black piece that goes from the headlight to the radiator. I think that is it ,,,,,.......
