no one knows the best or a good setting for the on and off temps on a pcm for fans?
<div class='quotetop'>QUOTE(ltn @ Jul 13 2006, 09:54 AM) [snapback]57973[/snapback]</div>whatever Allens sets most of them at. Works for mine.Quote:
Depends on what thermostat you have installed...
i got a stock one. i believe its a 195 if im not mistaken
Ok well just to inform you all i talked to someone in sales and they said that they can only run the fans to turn one on high when the a/c comes one. They can not do it with both fans on low. At least that is what this one guy told me, i didnt get the name though.
both fans on low until 230 degrees a/c or not and when its over 230 it will turn on both fans on high...makes more sense than getting really complicated with 1 on high,2 on low...whos on 1st....I gotta get some sleep :eek:
do u have a link to the design u guys did? O yeah the guy on performance trucks i believe only sells ls1/lt1 harnesses i dont think he has the connectors for the 05 fans.
Try this one.... http://forum.ls1truck.com/index.php?...pic=5076&st=20
my harness in this post runs the fans on low with the a/c on.
Here's what made USE2 happy... http://forum.ls1truck.com/index.php?showto...l=diagram&st=20
wait but those are for the 04 and up right, I have an 02. Is there anyway to get around it or do i have to let the amp draw go?
I am using the harness with a 2002 T/A-Camaro PCM.
