another couple questions sorry again for my ignorance. will my tbi bellhousing bolts work? or is that metric standard diff?if i found another 5.3 auto truck are those bolts the same? and also i found a starter for a good price but the part number is in reference to a 6.0 per denso's chart. will it mount the same? just the cranking power difference?also will any 5.3 startef bolt from the boneyard work or will my stock ones work?guessing those are standard in the 4.3 as well
i sincerely appreciate your guys help. you dont kno how much it means to me. i will for sure post updates with pics of him with it!
thank you sir!will i need new starter bolts? or are they the same?
oh and something else i wondered... i didnt get a MAF. will that be deleted in tune and just run a straight CAI?
Yup pilot bearing and nfw1050 flywheels. Arp flywheel bolts and pressure plate bolts. No complaints with that same setup in my truck.
I do believe you will need new starter bolts as well.. I have kept both left and right and oxygen sensors on my builds, I kept the MAF as well...I am not sure if you can have the engine programmed without those and the MAF or not... that would be a question for the tuner....
You can tune the maf out. It's called a speed density tune. Dont know anything about it lol. My build has front o2 sensors, no rears and a maf. Runs awesome
All.the bolts on the LS engine are metric, make sure to get proper belhousing bolts. 8mm I think?
yup 91ssp directed me correctly on that one have all those bolts ordered. sweet ill just let the tuner guy know to tune it out!
