here's a link to calculate the engine rpm. Final drive ratio at the bottom secton of the webpage should be set to .700 for 4th gear. Use the last section to calculate your engine RPM once you figure out what tire diameter you actually have. 255/75/16, I couldn't find that size tire listed but calculates at 31" diameter.
Engine RPM Calculator
