a new tbss intake is only $200 new from the dealer
anyone have a part number?
what is best TB to go with it?
tbss gm # should be 12580420 acc to my sources.....gene
thanks for the part number Gene...
Are either, NNBS 87mm or TBSS 90mm TB plug and play on an 04 5.3?
I dont think your opening on the manifold is big enough, but the throttle body should work just fine...
i'm sorry on the NNBS intake, but thanks
Quik is right. You'll have no bottom end with a single plane intake. The problem is compounded on a truck because it's very heavy
a light car with a good amount of gear(4.11 plus) and a loose converter or a 4 speed car will benifit to running a single plane intake.
Leaving my truck out of the equation since its slow, I guess you and quik need to send flaco a PM and let him know that his truck would pick up some et by swaping to a longer runner "truck" oriented intake. Matter of fact, you can PM casey too as he also runs a vic. jr. and his truck is over 4500lbs.
