Are you that mechanically inclined that you can install gears urself? Or is the shimming process and the tools needed not as difficult as it would be on an older vehicle?
Not hard to do, especially when you can buy a master kit with everything you need to do it. There's just alot of checking and rechecking involved that can get annoying.
Ok so i bought the bearings that jegs said fit...................and of course they dont.
So what the hell
I measured the tru trac bearing surface and it is 1.625
The LM-60349 bearing that is supposed to be correct measures 1.780
WTF????? anyone know what bearing i need or do i have the wrong tru trac even tho the part number shows it to be correct?
anyone have a clue.....i really need to figure this out!
Ok does anyone know what the correct bearing surface measurment is on the detroit tru trac.....everybearing listed to fit it has a diameter of 1.780, but mine measures 1.625?
Are you measuring the right spot? It's very possible that your tru-track is not the one you need.
ok part number on box-913A481
http://i123.photobucket.com/albums/o...n/IMG00077.jpg
bearing/race combo skeet sugested-
http://i123.photobucket.com/albums/o...n/IMG00076.jpg
http://i123.photobucket.com/albums/o...n/IMG00075.jpg
http://i123.photobucket.com/albums/o...n/IMG00073.jpg
measurment on tru trac-
http://i123.photobucket.com/albums/o...n/IMG00078.jpg
measurement of inner diameter of bearing LM-603049
http://i123.photobucket.com/albums/o...n/IMG00079.jpg
measurment of race LM5013014
http://i123.photobucket.com/albums/o...n/IMG00080.jpg
measurment of outer diameter of race LM-603012
http://i123.photobucket.com/albums/o...n/IMG00081.jpg
ok....more info i found.....the bearings lm-501349 and race lm-501314 cross reference to ac delco s13- which is a carrier bearing for a gm 10 bolt FRONT diff
is it possible i got a front tru trac?
nobody know?
This is out of Eaton's application guide.
10/1500 Pickup Blazer/Jimmy Suburban Tahoe Yukon Van Trailblazer (SS)
1964-72 GM 12 bolt car 8.875 1.29 30 3.08-3.90 187C197A 913A555 (pa) 19554-010
1964-72 GM 12 bolt car 8.875 1.29 30 4.10 & up 19555-010
1964-72 GM 12 bolt car 8.875 1.41 33 3.08-3.90 187C198A 914A576 (pa)
1964-72 GM 12 bolt car 8.875 1.41 33 4.10 & up 914A575 (pa)
GM 12 bolt car 8.875 1.50 35 3.08-3.90 187S196A (ch)
1955-64 GM 3rd member 8.2 17 3.90 & dn 19686-010
1963-79 GM 10 bolt Corvette 8.5 17 3.08-3.90 19670-010
(cast iron 3rd member) 17 4.11-4.56 19673-010
1988-96 GM 10 bolt C-Clip 8.5/8.6 1.32 30 2.73 & up 187C148A 913A481 19559-010 19659-010
1971-89 GM 10 bolt C-Clip 8.5 1.20 28 2.73 & up 187C149A 912A556 19557-010
1964-71 GM 10 bolt Buick, Olds, Pontiac 8.2 28 3.36 & up 19674-010
1964-72 GM 10 bolt Chevrolet 8.2 28 3.08 & up 19603-010
1988-05 GM 10 bolt 7.5/7.6 1.20 28 3.23 & up 162C59A 912A317 19599-010
1975-89 GM 10 bolt C-Clip 7.5 1.16 26 3.23 & up 162C58A 911A319 19663-010
3.08 & dn 911A415
(ch) custom housing with 3.25 bearing bore.
(pa) 30 and 33 spline units are made to fit axles cut with 45 degree pressure angle.
All GM 8.5/8.6Eaton differentials require special bearings. For axles with small bearing bores (race O.D. of 2.89), usually found on vehicles prior to 1999, bearing LM-102949 and race
LM-102911 are required. For axles with large bearing bores (race O.D. of 3.06), usually found on vehicles from 1999 to present, bearing LM-603049 and race LM-603012 are required.
1977-88 GM 10 bolt 8.5 1.20 28 2.73-5.13 187C149A 912A557 19557-010
To 1980 Dana 44 8.5 1.31 30 3.73 & dn 187SL16D 913A591 19695-010
3.92 & up 187SL16C 913A592 19747-010
1982-07 GM 14 Bolt IFS (HD) 9.25 33 All 19622-010
1982-89 GM 10 bolt C-Clip 7.5 1.16 26 3.23 & up 162C58A 911A319 19663-010
3.08 & dn 911A415
1988-07 GM 10 bolt C-Clip 8.5/8.6 1.32 30 2.73 & up 187C148A 913A481 19559-010 19659-010
1972-89 GM 10 bolt C-Clip 8.5 1.20 28 2.73 & up 187C149A 912A556 19557-010
To 1982 GM 12 bolt C-Clip 8.875 1.30 30 3.73 & up 187C150A 913A315 19556-010
2.76-3.42 19587-010
1981-07 GM 14 bolt C-Clip 9.5 1.37 33 All 225C135A 914A538 19590-010 19684-010
