4.10s will put you at 2250rpms at 70
4.56s will put you at 2503rpms at 70
Hi Jon. :wave:
what if i added 6.0 heads
Ok and i also wanted to kbow about spray if any what shot should i use? Abd will that combo run with a ext silverado with a 6.0?
Start out with a 100 dry shot. Easy HP.
If you go balls-to-the-wall on the 4.8L and spray it, you might outrun the 6.0L. But what are the 6.0L mods?
Stock 6.0
Yeah, you should be able to outrun him...
