Your running no stat? No stat usually makes the coolant flow too fast and has no time to cool in the rad. I didn't really read the whole thing, just saw no stat.
I will tell you this, and this goes for ANYONE pulling heads with the slightest possibility of gasket/head issues. If you do not remove the heads and take them to a machine shop to get checked, they WILL be warped when you put them back on with new head gaskets and nothing will have changed lol. Murphy says so.
As far as the motor running more rough than it is, you are talking about something that has infinite degrees of being "out", blown, or warped. A water pump is good, or bad.(or failing) A head gasket/head can have so many degrees of failing, maybe it causes a big problem, maybe it doesn't. Depends on the severity...which is impossible to tell from the outside looking in.
When the rad is filled up with the proper amount of water, can you see any "steamy bubbles" or anything coming out? Refresh my memory, does your radiator have a cap or is the cap on the filler bottle thingy? Did you play with the heater any, you should def put it to HOT to let the water go into the heatercore.(once the headgaskets have been addressed) Is that the same radiator that was cooling the truck before?
You should do a compression check.
EDIT: Are you running the turbo setup right now?
My truck has the cap on the overflow tank and when the cap is off it does make "steamy bubbles" which shows it is presurizing.
The heater acts funny though.. sometimes it will blow really hot air then all of a sudden blow cool air. Not sure what's up with that..(maybe air in the heater core?)
Yes, same radiator as before and its a 34 inch. Also I am running the turbo setup.
Compression test is a waste of time in this instance. Do a block test and if it fails then do a leak down.
You have a blown head gasket or cracked head or block. Steam bubbles are a small clue (can be caused by an airlock) but the heater doing that is combustion in the cooling system hence no need for a compression test....block test will prove exhaust gases in the radiator. If from there you wanna know which cylinder it is and where the leak is leaking into...do the leak down test. Compression tests are only good for the START of misfire diagnosis.
Well I took the heads off monday and saw a few bad spots on the gaskets. I went to a machine shop to get my heads checked and sure enough they were warped! Got them resurfaced and I also leak checked the valves. Finally got it running tonight and.. so far so good.. it's not overheating like it did before. Hopefully if the rain slacks off I'll be able to drive it more tomorrow. Thanks to those who helped.
Trevor
Hope its fixed man
