Well it depends on the history of the vehicle that you are sure of as to whether you should take the heads off and "tear it down" being that it is a budget rebuild, in my opinion. ChevyLee got burned by buying from someone across the country where the engine could have been sitting in a garage on a pallet for 6 months prior, it's hard to tell. My roomate blew up a 4.8 and got a 6.0 local, we bolted it in without cleaning it at all and it would melt tires like nobody's business. You just have to check the engine out before you buy it. I pulled from a local junkyard and popped the valve cover off when it was still in the suburban and saw no gunk on the valvetrain whatsoever, and full of clean oil on the dipstick. I cleaned off the top of the heads below the intake, and got new waterpump and intake manifold gaskets(they were both shot past reinstallation when i took it off) All in all, invested $55.00 in gaskets and simplegreen and carb cleaner. If you wait till later to cam it, you will save some fluids but most if not all gaskets are reusable. Get it running already!!! Haven't taken heads to a shop lately, but it ran like $150 for a valve job on some gen II sbc stuff. Id say around $200 to "clean up" heads, probably less. Did you purchase the engine under the guise of it needed some internal engine cleaning to run? If you bought it ready to run then bolt it up and go.
+1 If you can only afford to get it running then don't delay, time is running out!
Where did you source your motor if you don't mind me asking?http://www.ls1truck.com/upload/files/31/34intruck.jpg
