so can i use stock 6.098 rod length to make a 5.3 block into a 5.7L
with the stock ls1 pistons size. and a ls1 crank
Or you can bore it 3mm and buy a set of pistons and have a 5.7L
ok ls1 is a 3.89399mm bore rod is a 6.098 stroke is a 3.633
so i take the 4.8l / 5.3l block and i bore it 3mm. to make it a 99mm block, and then trash the 3.267 crank and thro in the ls1 crank. then just use the ls1 rods of 6.098
i thank thats right.
