With the amount of positive feedback that Seafoam is getting on this site, they should be a sponsor... Mods--forward this post to their marketing division and see if they will sponsor us... :)
I saw you can buy this by the gallon...course it was about 45 bucks or so but hey if you are addicted go for it.
Dave
Did a SeaFoam job on my DD (Honda Accord 2dr.) this weekend. I used a whole can--dumped 1/2 while at idle, then let the other 1/2 of the can soak for 15 minutes...After starting it, it looked like I had just done a dragster burnout in the driveway for 10 minutes! I then had to drive it around for 10 minutes for it all to burn off... BUT it does have a smoother idle, has better pick up, and I swear it's faster...hehe LOL.
After reading this, I am going to get some of this tonight and try it out on the 06 and see for myself. The truck has always not seemed to idle quite right for me, so I am going to give this a go and see if it does help it out.
I will post the results.
ducky your motor is already clean:D. maybe run some through your gas but theres no need to do the top or bottom end for about 20k miles.
haha I know but remember how big of an idiot I was when I told you how I kept the motor lubricated, (squirtin oil in the spark plug holes as well as every other orfice on that engine, then spinning it)? Well that just got me worried, especially after I trashed both front 02 sensors. Im just a clean freak when it comes to wanting everything on the inside to be spotless. I want to pull my 4.3 apart and see how clean/dirty that thing was, I kept up with it quite a bit as far as running stuff through it to clean it.
that oil was burnt out within the first 30 mins of running i would guess. dont sweat it.
yeah it was a pretty good smoke show for a while after I first cranked it.
Which vacuum line do I use to get the seafoam into the intake to sit overnight. I plan to put about 1/4-1/2 can in the intake, then the rest in the fuel tank, I just need to know which line is best to get the stuff to all the runners?
Any vacuum line will do, but I would go buy a tiny, little funnel to put into the vacuum line so you don't dump that crap everywhere... I think the vacuum line coming from the brake booster is the largest--I would use that one...
