Well I need my truck running today. Can I just make the v6 holes bigger do it will mount? The holes aint that far off.
i know it's inconvenient, but do it right the first time & you'll only have to do it once. i needed my truck running the whole 5 months it was down - i worked out of town & was having to borrow vehicles
I suggest you not feel bad about this any more, because this is typical. I actually expected it, but that's because I've been at this hobby for decades. I too had a broken coil and a cut harness with my LM7, and no harness at all on my LQ4, and neither included the engine computer. Even their chain work cracked one of my LM7's valve covers nearly in half. They're not gonna include anything they can charge you extra for by selling it separately, and they're not gonna be careful of the parts they expect you to replace. They're just a bunch of disgruntled minimum-wage guys, doing the bare minimum to keep getting their tiny paychecks.
Ya I'm not so sure whats so hard when I ask and pay for the whole engine wiring harness. To their credit, they felt bad and got me other cut half the next day along with 2 coils. The big question is if I'm going to be able splice and fix it.
New drama....
The machine shop called and said that I have a 4.8 and not a 5.3. I guess the crank size is different. My receipt said I bought a 5.3. Sooo the big question, do I take the engine back (in pieces) and demand a refund along with the machine work??? Or will a new crank bring the engine to a 5.3????
Thoughts.......
a 5.3 crank will get you a high compression 5.3 with those flat-top 4.8 pistons. as for any other differences - someone else can chime in on that
After a little research, I was bale to find casting info for the crank and pistons for a 5.3L engine and confirm that's what I have. No harm or foul for the machine shop. Looking at it now, easy mistake.
When i bought the V8 swap it came with the ecu and all connected. I tried too start the truck today and nothing. Starter dont turn over or anything.Theirs a key lock and car light on the guage cluster, that turns on when trying too start the truck. Do i need to get the key programmed or anything for the new ecu?
I installed my v6 ecu back into the truck, it does the same thing.
As far as i can tell everything is connected and installed correctly am i missing something?
Thanks
sounds like VATS needs to be disabled. who did your tune?
