Quote:
yea... i even loaded stock trans settings back to it. Lesson learned, I should've just rebuilt the first trans (which was an actual truck trans). The second trans was not originally a truck trans. I may see about getting FLT to rebuild my truck trans. Either way, I'm waiting about 3 - 4 weeks for a trans that works.
You might need to check out Performabuilt transmissions or even CPT transmissions....They are holding very well in high H.P. and the CPT trannys are quite a bit cheaper....You can go to Camaroz28.com to see CPT and ls1tech.com to see Performabuilt....
