Quick question i was laying out my np harness. It has a fuel pump relay included. Can i just cut the obs relay out and take the fp power wire to np fp relay
yes you can, hook the output wire to the grey wire going to the fuel pump.
03 2500 80e. We slid motor as far forward as dd mounts would let us. I did have to cut a splined portion off of another driveshaft for the front. I just welded it to the existing slip yoke. The rear looks good.
http://i1153.photobucket.com/albums/...8785554983.jpg
Crossmember in foward mounting holes.
http://i1153.photobucket.com/albums/...8785581105.jpg
Custom built front driveshaft.
I started it for the first time tonight. Fired right up. Holding 65psi oil pressure. Sounded great with strait manifolds. Seems like it was idled a little high. I didnt have a tach hooked up or anything.
Alnost there. Took it down the road for the first time. Something aint right it wont even spin the tires. Feels realy weak. It pulls pretty good after abot 3k. Nothing down low.
do you have 02 sensors on it?
Check your fuel pressure.
Do you have used cats on it?
Is it overcammed. 222/226 on 113. 596/597. Stock verter
Id like to edit an earlier post. It is real soft down low but pulls super hard after 3k. So hard it lifts the front end and i lose a little steering feel. SKETCHY!!
:laugh: You need a stall convertor, maybe 3600+ RPM.
My buddy was gonna youtube a burnout and everything. I hit gas and was like darn delete that crap.
bleach.
I got an up to date scan tool hooked to swap. When at idle my iac is registering 0 counts.
Got a weird problem. My abs light is on. When i push my ac button it goes off. My ac clutch wont kick in.
sounds like something is miswired, or shorting out.
Almost finished. All ive got left is to plumb my tru cool 40k in and tidy things up. I got my 05 truck fans in and working this afternoon. Those things are nice.
Ive put about 100 miles on it. It drives great except for being stupid over cammed. One thing I've noticed is no matter what i do my tps is at 1% my tps voltage is about .63 v.
PM ray and jon and see if they can assist, check pinout, ohm, etc.
You should ohm out the wires between the PCM and the TPS sensor plus double check the wires are going to the right PCM pin location. Have you tried swapping out to a known good TPS? Where are you located?
Finally ordered a stall verter from circle d. 32-3400 can't wait for it to get here
