I know this is an old thread but does any one have the part number to the 3 wire Coolant temp sensor I see the pig tail but not the sensor.
You won't really like the readings coming from the 3 wire sensor, they're way off. The 3 wire was only used on the 98 camaro/transam. Your local auto parts store can get you one. I use the 2 wire on the PCM, unless its a 98 camaro PCM, and a factory sensor from the original vehicle when doing a conversion to LS engine.
I have an 03 truck 4.8 and pcm was kinda not wanting to drill and tap or buy the apadtor for the one wire sensor.
does any one one what vehicle has the one wire 3/8 temp sensor.
92-93 silverado 5.7L
Thank you Found out the one for my 87 is a 3/8s also didn't realize it was NPT.
I need the part numbers for the earls fittings i need to use in my swap I have a 98 silverado from the plate to the ls intake
Shouldered bolts to bolt the clutch hat to the flywheel. I have the flywheel to crank bolts. Cant seem to find the other ones and I really dont want to pay a dealer price.
so i am new to this site and picked up a 2004 gmc savannah 3500 with a 6.0 and a 4l80e which i want to put in my 97 tahoe 4wd. i have the complete vehicle with 90k and runs excellent. so my questions are: i keep seeing hotrodlane for parts but the website doesn't exist, so i go to street and performance and can't find anything there either. so who has the motor mount adapters,flywheel kit to use my 4l60e, oil pressure switch extender, and all the other stuff? btw this was a former carpet cleaning van and has a pto and a throttle cable instead of drive by wire accelerator. should i use the 4l80e? can i adapt my transfer case to it?(manual shift case)also could i swap the hydroboost sytem too?any help would be great thanks in advance
