Allen,
once u told me my cams where not of ur likeness cause they where too off of what u will recomend.....
How about trying mine in ur dyno
230/232 @ .050 .580/.580 @ 1.7 112 LS
Allen,
Just throwing a curve ball in here Allen - Since most guys run a tight intake/exhaust duration (220/220, etc.), I'd like to see what a larger split duration would dyno at. A biased request obviously since I'm one of the few running that large of a split (218/228), but it would be nice to actually see numbers and have some real time proof of how a large split duration affects hp/torque. Futral said when running stock manifolds, the larger duration would actually help dispel the exhaust gasses and make up for the restrictive factory manifolds.
<div class='quotetop'>QUOTE(bluecajun5.3 @ Sep 13 2006, 02:00 AM) [snapback]64936[/snapback]</div>Quote:
biggest-
tsp 220/220 .581/.581 and tsp 224/224 .581/.581 both on a 112
im puttin in the 220/581 @112 ill let you knwo how it feels :lol:
<div class='quotetop'>QUOTE(TxStVanWilder @ Sep 13 2006, 05:13 PM) [snapback]64996[/snapback]</div>if i was keeping the 5.3 i would go with the tsp220 too. now im thinking the tsp 224Quote:
If your springs will handle it and I haven't sold it yet, I'd be willing to ship you my turbo grind cam so you can see how it works on that N/A 5.3L engine. The specs are in the for sale section.
how about doing this test on 6.0's as well i want a cam eventually, but idk what to get, i want a mild to moderate cam something that idles fairly rough but doesnt die, i want mac performance any suggestions here guys? links? sorry to jack the thread
im doingmy install tomorrow night on the cam so hopefully i can find my camera (since i lost it) and ill post up how it goes....
<div class='quotetop'>QUOTE(Allstar55566 @ Sep 13 2006, 04:55 PM) [snapback]65005[/snapback]</div>If you're looking for a great cam with very well behaved manners, the 224 cam is pretty good one for the 6L.Quote:
Thanks guys, I'll probably start with a 212 grind and end up with a mid 22x for the most radical. If time permits, we'll go as high as 230.
I like the idea of 112 vs 114. I think the power band will be very similar, however, the looser lsa will pick up on the topend just a bit. We may do that test as well. This comparison will probably be on a 220grind.
Keep'em coming.
thanks,
allen
mine is hte comp 216/220 .525 .532 on 114
Allen, I'm a little curious as to what will happen when I run the 110 cam I have. It was cheap, so I'll put it in and see what I get. Its a 228/232 .588 .595 110lsa. I think it may be a little big, but I am doing 4:10s and a 3200 Vigalante for a while until I get a big motor ready along with the turbo. I would love to have some heads done, but I want to see if I can be the fastest cam only LS based truck.
