Mine cycles on high with the A/C.
ok so how do i get one that cycles the fan on low when the a/c is turned on. i also have a 02 avalanche if that helps.
I'd call Allen and find out how it's supposed to work. It can be set up either way. John can answer your question if he's the one who answers the phone, he builds the fan harnesses.
ok cool i will try emailing him or ill call him tomorrow. thanks.
my truck works great with the 05 fans and Nelson Harness. this harness looks factory and is easy to install, i notice no voltage drop at since install. when i turn the a/c on 1 fan will run all the time. I can t hear the fans till i shut the truck off and hear them slow down. On my ride they come on at 190*. truck never runs over 190* and most of the time runs 180* according to my interceptor gauge. Stock gauge reads 210* but its LYING!! :lol:[indent]BTW, you have a 34 " Raditor? you have to have it for the 05 fans to work.
<div class='quotetop'>QUOTE(Tim Z @ Jul 12 2006, 07:32 PM) [snapback]57915[/snapback]</div>I wonder why mine cycles with the A/C compressor instead of staying on constant?Quote:
<div class='quotetop'>QUOTE(SCIV @ Jul 12 2006, 08:49 PM) [snapback]57916[/snapback]</div>mmmmm....? im not sure? maybe mine does that too and i dont notice while driving, i dont use my a/c that much as i dont drive my silv every day. i just know every time i turn the a/c on the one fan comes on , i never paid attention when it goes off. it seems to run the whole time but i could be wrong. That's whats cool about these factory fans, there real quite compared to the aftermarket fans ive heard.Quote:
does anyone know if i get the nelson harness, does the connectors for the fans come with the harness. i mean for the 05 e fans.
Yes, specify if you have the LS1 or 2005 Silverado fans when you order and they will put the appropriate connector on the fan ends of the harness.
what do u think the best temp for on and off settings should be with a stock tstat. thanks
