Quote:
First question, does the input shaft of the transmission have a pilot on the end of it about 1/2" in diameter? If so, that's a totally different transmission than the V8 trucks use. The LSx type engines use a 300mm input shaft that has nothing but spline at the end of the shaft. To use the old style transmission and TC you will need a spacer and bolts for the end of the crankshaft if you have the input with the pilot. You can redrill or slot the existing holes in the flywheel to match the proper bolt hole pattern.
i think i'm just gonna have to get a flywheel now. like a stock 5.3 flywheel ive been told should work.
