i have a 91 c1500 and am insterested in one of the lockers i think i have a 8.5 rear end, not exaclty sure, but if you know and it was at the right price..thanks
<div class='quotetop'>QUOTE(c1500 @ May 14 2006, 10:01 PM) [snapback]53139[/snapback]</div>a 91 could have 1 of 3 rear axles. if it was made and sold in mexico it has a dana 44(i bet some of you didnt know that???) standard 1500 has 8.5" some 7200lb gvw 1500 had 9.5" rear axlesQuote:
this is a 8.5" (or 8.625" in a 99 and newer)(10 bolt)
http://i69.photobucket.com/albums/i6...10bolt85in.jpg
this a 9.5" (14 bolt semi float)
http://i69.photobucket.com/albums/i6...orp14bolt9.jpg
i have one each factory eaton locker, 8.5 and 9.5 also have a trutrac 8.5 but sounds like it may be sold.
<div class='quotetop'>QUOTE(hummertech @ May 12 2006, 10:40 PM) [snapback]52970[/snapback]</div>Quote:
if i spent less time building cool trucks for every body else i might have time to do something cool myself. i know this is a gm truck site but when i get this jeep thing done that i built i have to post a pic,,, 1991 jeep wrangler, 2005 lq4 6.0, 2004 h2 4L65e, hummer floor shifter, atlas II transfer case, 6.5" lift, dana 60 axles,
super swampers, its out of the body shop now, painted, i am going to install the axles tommorow. the good thing is that the more side work i do the more stuff i will have left over for the people that really need it!!!! like in here...i got some cool parts comming up....whipple charger for a 7.4 vortec?????,,,anybody need that??? abs brake module 99 k1500???? front diff parts 1500???? lockers 8.5/8.625/9.5???? detroit truetrac 8.5-8.625???? 3.73 front gears, 3.42 front and rear gears????........its freekin crazy how much stuff builds up after working on gm trucks for 15 years... i'm tired of looking at all this stuff, my new 4 car garage wont have any car parts in it at all, just cars (all the parts will be in a room, i bleed oil, tools for life) :rock:
That Jeep is going to be bad@ss! :rock:
I've got a 90' Wrangler that I've been working. I was really thinking hard about sticking my old 5.3 into it but I've just got too many projects going on right now to start that one. Still got to finish the body work, 8.8 rear end and new gears. :sad:
Will any of those lockers work for a 01' Silverado front diff? My buddy is looking for one.
<div class='quotetop'>QUOTE(Zick @ May 15 2006, 10:04 AM) [snapback]53167[/snapback]</div>sorry, no 8.25 front lockers. i have some gears i think? i have to check. a 5.3 would kick ass in a wrangler.Quote:
it wont even overpower the 8.8 rear swap. this jeep was going to start out like that but has transformed into a freekin monster. it goes to show you, once you start, you cant stop...
<div class='quotetop'>QUOTE(hummertech @ May 15 2006, 02:52 PM) [snapback]53183[/snapback]</div>I know that problem all too well. :laugh:Quote:
Don't worry about the gears, he was just looking for a locker is all.
Thanks
:pics:
any news on the true trac?
I thoguht the detroit truetrac was one of the best posi you could buy for these diffs. But if its only 80% torque to one wheel and 20% to the other that sounds like once could still be friying and the toher just start to spin?
Still interested tho.
<div class='quotetop'>QUOTE(onebadrubi @ May 15 2006, 09:26 PM) [snapback]53228[/snapback]</div>its acutually 80% of the torque to the one wheel that need the traction. picture this,,,,, lift one rear tire off the ground about 2 feet,,,your truck in 2wd,,, so now you only have one tire to provide traction,,, that one tire gets 80% of the traction. the tire in the air moves a little bit but the one on the ground gets almost all of the power.. the trutrac is probably the best posi for a preformance street rig. that 20% remaining to the other wheel is what allows you to turn corners. its a bitch to turn when the rear diff locks up solid...if you had some good power you will have no problem getting both rear tires to fry, all the time. the way the gears in the trutrac work its almost impossible to spin just one tire. that tire would have to be stuck against a big rock and some tree root to keep it from ever moving and then you would probably brake something rather than get just one tire to spin. its because of that i didnt want it in my front.(ive been there and would have been stuck)i have a gm 8.5" 10 bolt in the front of my jeep.Quote:
OK NOW BACK ON TRACK. i like to talk shop. there are too many girls in my house and it gets bottled up. pm me your shipping address and i will get you the killer, never offered again, one price deal. shipping included. also tell me what year of truck its going into. this diff is out of a 98. they work on newer 99 and up axles but need the correct bearings installed to fit in the housings. the 8.5 and 8.625 mount on the same carrier (i have newer 8.625 rear gears in my ond school 8.5 front axle, 4.88 ratio). once i know what bearing to get and how much shipping will cost me, i will shoot you a deal you cant say no to.....
one detroit trutrack, two new carrier bearings installed, two bottles of gm synethic axle lube, & a new cover gasket.. is that enough? :rock:
pmed you hummertech. Also gave yo umy phone number. You can call me tommorow with the price that way money could go out then!
<div class='quotetop'>QUOTE(onebadrubi @ May 16 2006, 05:15 PM) [snapback]53301[/snapback]</div>SOLD!!!! ONE TRUETRAC, TWO NEW BEARINGS, GASKETS, AXLE SEALS, SHIPPING FOR $200.00.Quote:
THANKS... :thumb:
