I had turn downs right off the muffler for a while and I think it sounded better but was just to loud at 5am. My neighbors probably hate me enough as it is.
Ran out the back like in the picture I believe it is in the second post would be clean! Even if it's single 3". I've ran it in front of the tire on multiple setups and the only would that didn't sound flappy was my 3.5" 5x11x22" magnaflow setup I had on my crew cab. Others had any annoying flow master sounding flap in it. I'll post videos with details on the entire exhaust.
5.3 220/224 .53x on 112 cam, longtubes, ORY, 3.5" pipe from ypipe back. 3.5" shootout pro spintech turned out in front of the tire but not visible.
http://youtu.be/C2gMmxPDLfc
6.0 lq4, milled 317s, 212/218 cam, LT with ORY, 3.5" from ypipe back to 5x11x22" 3.5 si/so offset magnaflow turned out in front of back tire.
http://s194.photobucket.com/user/red...2_551.mp4.html
6.0 ls2 stock manifolds, no cats, 5x11x22" 3" si/so offset magnaflow into two pypes tips
http://youtu.be/Tgke66664AY
5.3 220/224 .53x on 112 cam, LT with ORY, 3" si/so offset magnaflow 5x8x18, can't remember if it was behind the rear tire or in front of it here. Pretty sure it was behind it tho with 4" tip. Probably my favorite setup on this vehicle.
http://youtu.be/cCmzIgn75Lg
Bone stock 5.3 4x9x14" si/so 3" magnaflow behind the tip with 4" tip.
http://youtu.be/qiXcf_79xkU
Brother's truck
2012 5.3, ls1 cam, LT with ORY, 5x8x28" magnaflow exhaust exhaust to look factory.
https://m.facebook.com/story.php?sto...00001519844903
I went with 3in pipe with a y pipe haven't finished it yet tho, I guess ima get a borla xr1
Here's my setup, schoenfeld headers, 2.5 mandrel tubing, borla pro Xs mufflers and generic tips. Sounds pretty awesome, also I used V-band clamps for my joints.
Attachment 9317Attachment 9318
Shoenfield's, 3" back to some old flows and turndownshttp://img.photobucket.com/albums/v6...92A1C0391F.jpg
http://img.photobucket.com/albums/v6...50F357D0A4.jpg
